Results 1 to 6 of 6
Thread: 2007 GT stroker missfire and leaning out
    Mar 2018
    4
    Hi.
    Have big problems whit a 2007 mustang GT.
    It has a 5.3l stroker engine 11:1 compression
    Ford racing "hot rod" cams
    Longtube headers.
    Ford racing intake and throttle body.
    A shop have built the engine and made a "start up tune" whit SCT for it.
    And tolde the guy to drive it for a while and then finish the tune. But its almost not driveabel.
    Its is runing pretty ok on very light loads but as son it gets some higher loads its start leaning out and missfire.
    They dont whant to deal whit it. So he asked me if i could have a look at it.
    No fault codes.
    Have tryed to adjust the maf curve it dont reakt to it.
    Any one have any idea what to look at?
    Mar 2018
    4
    Nobody?
    And excuse my english, from sweden.
    Jan 2013
    Hawaii
    2,101
    What Fuel and injectors?
    Mar 2018
    4
    Petrol swedish 98 octan think thats like 93 in US,
    bosch 0280158279
    Jan 2013
    Hawaii
    2,101
    I would put your Open Loop TPS threshold table back to 50% or 56.6%, so that your narrow bands are active in more of the MAF failed table. You can populate the load and get fuel dialed in with those for the part throttle stuff. You will also be able to diagnose air leaks much easier with out it going into Open Loop unnecessarily, so quickly.
    After you raise that up, add 10% to your entire MAF curve and entire Load with failed MAF table. Log it, stay below 60% throttle, and see if your part throttle short term fuel trims respond to those change. If they do, you should be able to populate that part of the MAF and load table. If they don't, you will need to diagnose where its leaking air (intake or exhaust), or misfiring.
    After that you will need to start using your wide band. It looks like you have an LC2 and are using the predefined PID. Is this information accurate?
    Mar 2018
    4
    Ok will try this, thanks!
    I have tried to change the MAF curv 10% up and down befor whit out any other changes but no respons.
    Will do the other changes first and try again.
    Yes i have a LC2 hooked up.
