I picked up an 06 GT recently with 73k and lots of mods (see sig) that appear to be fairly old. Came with a crappy tune that had the PCM locked up with no way to find the tuner. Bought a reman PCM and sent the paper weight out to reprogram in hopes for a spare (it was only 150 bucks so why not). Decided to do the tuning myself as I've tuned before, might have been 10yrs ago. Mostly to spare myself the issues that come with canned tunes, unavailable tuners so I can't change whatever whenever etc....
The car runs and drives pretty good and everything seems to work, with one exception. I think it has a vacuum leak that I have yet to find.
I started with the stock file on the reman PCM and compared it with a half dozen others and found it reasonable to believe it's good. On startup as soon as the cold start fueling was done it would stumble and stall before the fuel trims had a chance to try to correct anything. I could tell it was real lean. So I dropped the stoich to around 13 something and it ran, sort of. The fuel trims were still positive but at least it ran. "The maf transfer curve hasn't been calibrated". I thought that's it! So I messed with it till I got 5% total fuel trim correction with stoich back to 14.64 all the way till WOT. We're burnin' tires now fellas'! Just can't get that trans to shift right. Well I found that we're using them maf numbers to calculate load which everything else is using too. So I look at my maf curve numbers again and compare to the stock file and WOW, they're about 30% more! So I go to the injectors to look over the flow rates and they seem ok to me. I did lower the flow rate numbers by 30% and returned my maf transfer curve back to stock and yep, it ran great. But as always, when you try to band-aid a problem with tuning the wound just gets deeper. "We're in the weeds now boys".
I replaced the bank 2 upstream O2 because it seemed lazy and was late responding and it seems to match the bank 1 close enough now. (clue?)
Ok, It may not of happened "exactly" that way but it's an entertaining way to show a few truths.
- I proved you can't band-aid a mechanical issue with a tune
- The car is running 30% excess fuel (minus the correct maf transfer curve) and likes it
- The issue can't be an exhaust leak because that would dump excess fuel in and stall. This thing wants excess fuel
- We must have unmetered air entering the manifold somewhere
- It needs to have the correct maf curve transfer numbers in before I go any further
- I can't find the leak
So with all that mumbo jumbo, is it really a vacuum leak? Could it be that not tuning the VCT adv/ret for the cams yet cause this? I wouldn't think by 30%(minus the correct maf transfer curve). I can't believe it's actually using that much air. Am I missing something?
I just need to find that D$%N leak, that's my theory. Share yours if you'd like, or giggle and move on for more entertainment. Have a great day!
[ATTACH]114165[/ATTACH ]10721.hpl
