at the 4-5 gear changing, the spark timing is pulled too much.
Is it due to the rev. limit? the highest peak of RPM before the point, it is just 6590 RPM as I set the cutoff at around 7000~7100 RPM.
and the schedule of shifting is like the above.
1. What factors are limiting the rev?
2. I would like to change the shifting point like 6800 RPM.
What should I need to change?
Thank you in advance.
