2004 Yukon 5.3 converted to DBC and SD. 209 / 217 camshaft. 25 lb truck injectors and fuel rail at 58 psi fuel pressure.
Throttle setscrew and TPS adjusted. 6 g/ps added to idle airflow
Freshly built engine, 4" intake and 2.5 exhaust. Very basic.
The engine needs the throttle cracked right after startup then is setts down fairly well.
I have been logging in closed loop and correcting the VE. The engine is beginning to idle smoother but there is NO WAY IN HELL the VE numbers are correct.
What could be throwing things of Injector data? Idle Airflow? Other adaptives or something?
Looking for advise on what to research, log, test to educate myself?
Green YJ Base Corr 10 12 Test see notes plus VE corr.hpt
21-10-12 18-01-22.hpl
