Results 1 to 1 of 1
Thread: SD 1bar table going lean rich after reflash gen 3 issue?
    Hello, I am having an issue with my SD tune ve tables going lean rich after reflash. Maf is showing failed, iat has been moved in front of radiator by bumper, and the channel pids look to be reading correct. I read about the injector tip issue but it seems that is for gen4 cars. I changed the VE Multiplier vs. RPM vs. TPS to 1.15 to see if it would fix this back and forth lean rich but it looks to still be swinging. If someone could chyme in on this issue for gen 3 i would appreciate it. If not I will read some more as i am sure the answer is somewhere in all of these feeds.
