Results 1 to 2 of 2
Thread: Chevy Cruze turbo / BoostLimit vs ECT
    Dec 2019
    6
    Hello
    on the Chevy cruze 1.4turbo with the Delco E78 is it possible to limit the boost depending on ECT or oil temperature ? I can only find an rpm cut off vs oil temperature
    Is it possible that something has change in the sowftware, I have something in my mind that I saw this option before
    Thank you
    Aug 2016
    386
    Short answer is no.
    The long answer is there are tables that allow you to specify TORQUE limits based on oil temperature and engine run time. As I recall those features aren't enabled on those calibrations, and the tables may not even be available via hpt for that particular ECM.
