M276 Knock Sensor Cyl Values
Hi all,
Trying to make sense of Knock Sensor Cyl outputs. It's given in voltage, which makes sense but the values range from 4-10v when idle/normal throttle, at WOT it's hitting 70v. So obviously it's not actually in volts. There's also a Knock Intensity reading which stays at 0. I'm getting no timing retard so I don't think there's any actual knock but I'd like to be able to interpret this output.
Thanks,
I'm guessing it is some sort of probability or other stepping. I'm guessing something over 70 means there is knock, maybe 100?
Hi
Actually, voltage is like "volume/sound" (almost like decibel). It is not the knock. The ecu will try to hear sharp spikes from the engine noises. You can reduce noises by adjusting a cylinders pressure with the vvt.
