Results 1 to 9 of 9
Thread: Cant get car started
    Jul 2021
    4
    Hello,
    I have a vehicle with a LS3 and walkinshaw blower on it. Ran fine then had a small fire and melted harness. Purschased a GM Performance kit including e67 ecu. Previously vehicle ran on Map sensor only. The kit came with all sensors obviously and all are plugged in. I will include tune that i ran previously that i copied everything over to new ecm. Im supposed to be driving this tomorrow. Anything helps. Thank You!
    7,619
    That's not a lot of info. Does it crank over but no start, or just do nothing? Does the fuel pump run? Do you have reference voltage at the various sensors? Did the melted harness blow any fuses that haven't been replaced? So many unknowns.
    Jul 2021
    4
    I apologize. Crank no start, confirmed fuel and spark. All sensors have refernce. Only DTC's are p2122 & p2127
    7,619
    Certain throttle codes will prevent the engine from running. Gotta fix those. Those two are for both of the sensors in the APP - it has no idea where the pedal is if it's got no signal return from either one.
    Jul 2021
    4
    Cranking log
    7,619
    Did the kit come with APP - and did you use it, or keep what was in the car from before?
    Jul 2021
    4
    Yes it did and it?s connected and reading from 29%-98%
    7,619
    That sounds more like TPS readings, not APP. APP is the sensor in/on the pedal inside the car. Those two codes are indicating neither APP1 or APP2 are working. Diagnose those codes.
    Jan 2012
    South Dakota
    44
    I agree, not a lot of info here and I'm not sure what's going on either. Were these both the same harnesses and ECU's? I do see under the OS tab your TCS patch etc are not applied in one tune and applied in the other. Not sure if that will fix your problem or not.
