Results 1 to 3 of 3
Thread: Low octane to high octane tables . How long for switch
    Feb 2013
    28
    Can someone direct me to how the computer switches ?
    I was told by a tuner that the high octane table is used at first but if the ecu sees knock it will switch to the low octane and be kind of locked there till 20-25 key ons ?
    Anyone have a link to explain this or can explain to me
    13,559
    Log the channel called knock learn factor. That will tell you exactly what it is doing.
    The channel either goes 1 to 0 or 0 to 1 depending on what vehicle/computer it is. So for example if it starts at 1 then you get a bunch of knock, it will work it's way down to 0. If the high octane table was at 20 degrees and the low octane at 14 degrees, then at .50 KLF it should be asking for ~17 degrees.
    The less that it knocks the faster it works it way back to only the high octane table. It has nothing to do with key cycles.
    Feb 2013
    28
    Thanks I will do this !
