Can anyone see why this truck is cutting all fuel when I floor it? It only does it sometimes, and then other times it acts perfect. One log it acts good and the other two logs it is like it hitting a fuel cut or something and it cuts the injector pulse down to nothing and the truck dies. Could it be a tune issue, ecu issue, ground issue, cam or crank problem. I would kinda think it wouldn't though because rpm signal is working good on the log, but then again I haven't ever seen what a crank sensor going bad is like. I have other vehicles with very similar tune setup and haven't ever had this issue. thanks
