Results 1 to 3 of 3
Thread: 2 sd tuning
    Aug 2013
    australia
    364
    2 sd tuning
    Hi guys when doing a late model e38 and a 2 bar sd tune do I write entire to the ecu as well as the fuel pump model or just do the ecu and leave the pump module? Cheers
    13,564
    Just the PCM needs a write entire if you are doing the 2 bar OS change.
    Aug 2013
    australia
    364
    Cheers thanks
