I have made many posts about this problem over the last year. I recently swapped my 60# Motron injectors for some smaller 42# Lucas injectors with the hopes that this would resolve my surging issues. It did not make any difference at all. I have read, searched and tweaked the tune with very little good results. The only thing that seems to help is when the problem area (40 & 45KPA at 1.6 & 2.0K RPM cells in the VE table @ 4-8% TPS) is made rich like in the range of 13.0 to 13.2 AFR. I'm not sure if that is the solution or not. It seems like a band aid. I really wish that I new what I should be scanning to find this particular problem. Some have said that the answer is in gettng the VE table dead nuts. Not for me. Others have said that the answer is in the RAF (it is dead nuts). Not for me. Others have mentioned timing. Not for me. Others have mentioned the Throttle Cracker and follower tables. These tables are magic for me and I cant seem to figure out what it is that I should be scanning in order to determine which way I should move which cells. Please look at my tune. It is called 2bar 98z28 surge fix smoothed because I got the VE table dialed in and then smoothed it. As for the surge fix part of the name, that is just wishfull thinking. Some background.
I am running in Open Loop Speed Density and I am tuning with an LM1 wideband that is logging thru the EGR. I am using the 2 bar SD upgraded OS simply for the improved VE resolution. I am not using forced induction or any special MAP sensor. My mods are listed in my sig below. I don't think that it is the cam as I had a slightly larger cam before and went down to the current cam and have the same exact problem. PLEASE PLEASE PLEASE HELP!!!!!
I am receptive to anything at this point. Please post a config that I could use to scan the correct PIDs, custom or not.
