Running a 4l80e behind a lq4 6.0. In a 91 k5 blazer. Running a 208 transfer case with manual speedometer. Question is if I install a reluctor ring in the rear of the transmission I would assume the transmission would work as if it was a 2wd instead of a 4wd. So I would have input and output speed correct?
