So dicided to bit the built and install the 6.0 3row alununuim radiator and efans in my truck. the truck was original a 4.8l and is now a blown 6.0l with a 4l80e swap. With a Nelson Performance HP tune. So when i had it tunned by Nelson Performance last year just before thanksgiving i had them program it for efans knowing that before holloween this year i would be doing the efan conversion. So I ordered up a bad ass radiator stock efans and the aftermarket harness to pin in to the ecm. Now time comes to install it all i pull out the fan clutch wont need this into the trash, fan shoud into the trash radator out side for the for the scrappers hoses into the trash. Then i install all the new stuff with new silicon hoses stainless clamps the stock fans and the new relays and harnes per the instructions avalible to us all via the interent. It should have worked perfectly right. No Not me Not so lucky. I started the truck and the fans came on at high speed right away the engine cold cold. I run it anyways and burp the system. I figureded ill figure it out the next day. So I plug in my Snap-on Ethos and go into the diagnotics and find the section for conntroling the ecm output controls ingictor silinoids fans basically you can turn everything off and on to check functionality. I start it up and what do you know the fans are on already and the engine is cold. I turn off and on both outputs and the fans go off and on in the cycles as they should. OK now we know that the outputs are connected correctly maybe its in the tune.
I contact Allen from Nelson Performance and we go back and forth email because he is in texas and I am in Cali. He says it is the harness and to buy his harness and it sould fix it so I buy tthe new harnes. Then wait a week to get and then i install using his instructions the same exact way i had just done the othe pin out. What do know same problem. I start the motor cold and the fans are on full speed humming away. I then go through the whole thing again check the ecm output yep throwing a ground, snap- on tool check the on off function yep that works. Now its been a month and i cannt get these efans to work right. Allen has no answer, all i get is hes done 1000s of these efan conversions and never seen this before. My questionis has anyone on this hp tunners forum ever seen this problem when using an hp tune.
