Greetings,
I have a couple questions about a couple of the settings for this trans. In TCM-40232 has several "clutch fill time" maps. It says, "this is the time to fill the hydraulic clutch on the shift". The question is, does this value actually *set* the fill time or does it simply specify what the existing fill time is? Same over in the Adaptive tab for the "clutch slip times". The description is worded a little differently and it seems to be that these maps actually do *set* the actual slip time of the shift members. Same for "Torque Transfer Time". Do we actually set the time values for the events? I'm a bit unclear exactly what torque transfer time means as well. Is that the overall time to complete the shift? These are in the Adaptive Settings group which I'll probably end up disabling anyway. Those "clutch fill time" maps aren't in the adaptive settings so I'd like to understand exactly what that is. I'm very fussy about trans operation, even light and part throttle shift quality and feel. There are plenty of adjustments so I'm sure I'll find exactly what suits me.
Many thanks in advance!!
