Are the analog inputs from the pro link cable with mpvi2+ supposed to work with standalone logging? They do not seem to show up for me in the logs.
SHUETUNING
Powertraincontrolsolutions
I have not gotten that far yet. I assume it you have the correct Channel configuration set up and loaded in your VCM Scanner and you then send that configuration to the MPVI2+ using the "Channel Configs" in the MPVI Standalone Data Logging Functions box. Good luck I plan on using the function also.
At least with the MPVI2+ and the Prolink+ they currently have the two Analog channels working in Standalone with firmware 5.1.17
The CAN channel is still vanishing in stand alone
so Half Fixed!!
