Results 1 to 6 of 6
Thread: Need help on WOT FAR
    Sep 2021
    35
    So I added some fuel to that one table that adds to the stoich to command an 11.4 FAR. Yet on wot the widebands are still reading stock. 12.0 to 1 on wot. This is on E85 with ID1300 injectors.
    I am a novice and there must be at least one more table I must up.
    Can anyone point me in the right direction as to if there is another table I need to up in value to get the actual result of 11.4 to 1 instead of what I have now?
    Nov 2009
    All Around
    3,149
    if your reading off your screen display that is different
    depending on your Ethanol mix you need to adjust your stoich settings
    Sep 2021
    35
    When I put in the 9.85 value in those three tables the car runs horrible. Is there another table that needs to change? Thanks for your assistance.
    Nov 2009
    All Around
    3,149
    you are new to dodge
    factory is .0722 which you need to calculate 1/.0722=13.85
    if your going for E85
    for ethanol of 85% 1/9.85=.101
    add fuel to the ve tables will give you what you want > for wot give fuel to the bottom right corner which is the wot aria i guess it takes 4 or 5 rows start from 60 and bellow
    Nov 2017
    816
    Quote Originally Posted by GeForce1986 View Post
    VE tables won't be active on a hellcat and I would not suggest turning NN off to make them active.
    Alphacat, make sure you understand the mathematical difference between FAR and AFR.
    If in doubt, multiply everything by 1.1.
