2012 ford mustang gt 69mm throttle body numbers
cant find the number anywhere
your asking for twin 69mm?
I'm assuming your wanting data for the VMP TB. You Might need to build the data with logs using the data from a twin 65mm. Setup your histogram with Effective Throttle Area on columns, and rows with Manifold Vacuum--ETC inHG. Then log ETC Throttle angle error.
After populating the cells take the values and add them into your ETC Effective Area Calculator. Rinse and repeat until ETC Throttle angle error are minimal.
