Results 1 to 6 of 6
Thread: Got another beef with this build w/ 4L60E
    Oct 2021
    Benton Ms.
    29
    4L60e ?? Wrong Place 🤦*♂️
    Moves fwd in 1st gear like normal into 2nd it goes about 1/2 way through the shift an into what is like neutral and will rev on..
    If you're not in the learning curve you've given up on education..
    Oct 2021
    Benton Ms.
    29
    I took it for another spin and when it does this I can pump the pedal a few times real quick and it'll catch up at a higher rpm,, possible TB response and or position issue..? Why and how would it respond to a DBW that way..? Help,,, lol
    Mar 2011
    Ripley, MS
    1,865
    Quote Originally Posted by LC9er View Post
    It's commanding 3rd and 4th gears. Make sure that the transmission is full of fluid. Also make sure that the fluid isn't burnt. It may be time for a freshen up.
    Oct 2021
    Benton Ms.
    29
    Thanks for the help,, its full of fluid, i had to add some after engine install and the old still looked good.. 223k miles, probably about that "time"..
    7,619
    Have you undone changes made to the tune file since this issue started?
    You do have an untouched copy of the original file that was in the truck from when you started, right?
    Have you read or watched beginner's guides to how to read-save-edit-write?
    Why do you have a P0300??
    Since this is another new thread, can you give a recap of everything that's been done? Hard to keep track when it's spread around all over. Someone who reads this and hasn't kept notes on previous sagas might not know what's going on.
    Oct 2021
    Benton Ms.
    29
    No, Yes, Yes, I'll work on it..
