Results 1 to 14 of 14
Thread: 2021 Can-Am Maverick x3 Turbo
    Oct 2021
    15
    Does anyone know if there is support for the 2021 mavericks? The supported vehicle list says up to 2020 for the maverick and up to 2021 for everything else. Thanks.
    Jul 2017
    529
    Quote Originally Posted by DSoutlaw View Post
    Only the ones that use the Bosch ME17.8.5 ecu.
    Oct 2021
    15
    Okay, makes sense. Thanks. Was doing some research and according to S3 power sports, there was a manufacturing change in November of 2020, and they don't offer ecu tunes for the mavericks after that manufacture date.
    Jul 2017
    529
    Only the RR uses the new ecu, all other models use the old ecu. So, if you buy one to mod, buy the lower one, so you can flash it.
    Oct 2021
    15
    Okay, thanks for the info.
    Feb 2017
    Billings,MT
    97
    Mine is a '21 Turbo R and built before Sept '20. So, I should be able to tune it.... correct?
    Jul 2017
    529
    Quote Originally Posted by XxScottxXN View Post
    Yes, if it has the Bosch ME17.8.5 ecu
    Nov 2013
    8
    Does anyone happen to know the model of the ECU that is replacing the M17.8.5 in the RR models? Can Am list their part number as 420464483, but I haven't been able to cross reference it to the Bosch number.
    Quote Originally Posted by jh122877 View Post
    does anyone happen to know the model of the ecu that is replacing the m17.8.5 in the rr models? Can am list their part number as 420464483, but i haven't been able to cross reference it to the bosch number.
    mg1ca920
    2008 J2 F-350 CCSB
    Aug 2020
    4
    I wanted to offer my late MY2021 RR ecu (build date after Nov) is can-am partzilla number 420-464241 has bosch 0 261 S10 15G on the cover. i believe this to be the tricky one that is being tuned via boot/service mode tricks on the board. Hoping this will change eventually. Unable to find specifications or much detail of any kind about this ecu.
    Last edited by cyphers; 01-09-2022 at 02:41 PM. Reason: specifying model of vehicle
    Oct 2007
    Crawfordville, FL
    2,553
    Supported now!
    Eric Brooks
    HP Tuners, LLC
    Mar 2019
    Ogden, UT
    102
    FINALLY! Thank you!
    Mar 2019
    Ogden, UT
    102
    Quote Originally Posted by Eric@HPTuners View Post
    Supported now!
    Are these a VR or physical once the unlock is done?
    Oct 2007
    Crawfordville, FL
    2,553
    Quote Originally Posted by JustDSM View Post
    Its a virtual read.
    Eric Brooks
    HP Tuners, LLC
