Results 1 to 8 of 8
Thread: help with shift points
    Sep 2021
    20
    I am new to tuning but i am doing my own tune on my ram everything is going good except for wot shift point. i believe i have everything right but i must be missing something here is the tune and wot log.
    thank you for any and all help
    jeff
    06ram07pcmtuneswaptrans8test.hpt
    hpforum.hpl
    2006 ram 5.7 4x4
    90mm throttle body
    Comp thumper cam
    Mild port and polish on heads
    Full headers with off road y pipe 3? single exhaust
    8 speed out of 19 ram thanks to Sound German
    m112 supercharger
    Sep 2021
    20
    i was originally going for 6200 but dropped it to 6000 but still having problem.
    2006 ram 5.7 4x4
    90mm throttle body
    Comp thumper cam
    m112 supercharger
    Nov 2017
    816
    And that's what happens when you turn off all torque management.
    Also, exactly what engine RPM is 2016 output shaft rpm in that gear?
    If in doubt, multiply everything by 1.1.
    Sep 2021
    20
    6048 rpm in that gear. So you are saying I need to turn on tq management?
    2006 ram 5.7 4x4
    90mm throttle body
    Comp thumper cam
    m112 supercharger
    Nov 2017
    816
    Yes, removing all torque management is not good. You can calm it down, but don't remove it.
    I'm assuming you're trying to set the 1-2 shift with the shifter in D? Is the tow/overdrive light on?
    It takes time to complete a shift, so you have to target a lower rpm than your goal, especially in 1st gear and especially with lower gear ratios or more power.
    You also have to consider any torque converter slip and subtract that from your shift target. It's not unusual to see 200rpm slip at redline from converter that doesn't have a clutch applied.
    Sep 2021
    20
    Ok so do I need to output shaft shifting to say 6300 if my wot is set at 6000? Is that where my problem is.
    Thank you for your help.
    2006 ram 5.7 4x4
    90mm throttle body
    Comp thumper cam
    m112 supercharger
    Sep 2021
    20
    And yes I am leaving it in drive. Also I pulled all tq management trying to figure out why at wot when I pass 3000 rpm the power comes on like I have boost
    2006 ram 5.7 4x4
    90mm throttle body
    Comp thumper cam
    m112 supercharger
    Sep 2021
    20
    yep i need help with shift scheduling i still cant seem to get it right.
    2006 ram 5.7 4x4
    90mm throttle body
    Comp thumper cam
    m112 supercharger
