Results 1 to 4 of 4
Thread: MAF table not populating
    Unhappy MAF table not populating
    Hi so I cannot figure out why my maf table is not populating I pretty sure it is set up right, I even downloaded goat rope garages tables to see if mine were wrong. Hp tuners is logging my wideband in lambda and it is showing up in the tune file I also logged the mass airflow sensor in frequency and then equivalence ratio.
    here is my log file
    work plz.hpl
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,265
    works fine for me, you are likely just not setting up the histogram properly.
    Feb 2017
    TX
    761
    Make sure you're logging the PIDs needed to calculate the "Eq Rrr maf". Should have a custom math button in tools or one of the drop down menus best to File and Edit. There you'll find the formula.
