Hello friends,
Does anybody have an hpt read of the gm 100 octane mapping?
This calibration could be ordered from gm for models 15 and 16 for track use.
I would like to see when they start to pull timing at high IAT.
Best regards
Max
Hello friends,
Best regards
Max
I dont have the file unfortunately but can lend advice atleast. Typically if your in a rather cool environment, i set my aggressive reduction (-10 or more) at 100* over ambient. So say its 70* that day, then set 170* and up to -10 and i usually blend it down a few cells after seeing what the temp maintained typically is for an average lap. This obviously is one mans opinion and is subject to how aggressive the calibration is already, but i tune many many C7s that run very hot environments 90+ and havent had a failure to date. Hope this helps.
c7zs run hot even with all the cooling mods. Usually start pulling around 150 myself, and aggressively around 100 over ambient but not necessarly -10. Do a few plug reads and find what it wants at your operating temps.
