Ba Falcon I6 auto full manual conversion issues
Hi all,
I have recently fitted a Shift kits Australia BTR/ION BA / BF 4 speed Full Manual Transmission Controller to my BA N/A Barra powered Falcon,
along with with a B&M Pro Ratchet shifter, as advised in the fitting instructions.
I re flashed the PCM, in the process changing the transmission default setting to manual.
Unfortunately, it will only select 3rd gear, which is the default limp mode setting.
Everything else is ok, Park, reverse, neutral etc., plus the neutral start inhibitor & reverse lights are all normal.
Being a newbie with this tuning platform, I'm not quite sure where to proceed from here.
I have tried flashing a file from the repository, without success.
I'm waiting to hear back from Shift Kits in the hope they may be able to offer some help.
Has anyone on here had a similar experience?
I'm going through this process as I have a Barra turbo in the wings, which I'll fit up, along with a stronger BTR trans, in the near future.
Any help /advice would be appreciated....
Ray
