Results 1 to 6 of 6
Thread: 2015 golf 1.8t setting up launch control
    Sep 2021
    can someone help me set up launch control? new to tuning with hptuners
    May 2014
    USA
    452
    What kind of transmission? OEM launch control is thru TCU/DSG
    Sep 2021
    5speed MT
    May 2014
    USA
    452
    Not built into ECU functionality sorry. The companies that offer it for MT cars are using custom added logic.
    Nov 2008
    Tampico Bay, Mexico
    220
    i manage to do some help to boost/launch but in a older 2008 gti MT in the rpm limits i set the limit in 4K in park neutral so as long as you have the clutch ppedal pressed it will cut at 4000rpm and with that cut i build like 4psi at neutral with the gas pedal all the way down ...you just release the clutch and the limiter jumps to 7000 and the car launch hard i know the fuel cut table is diferent on the newer OS it doesent says par neutral it says 0,1,2,3,till 7 so just have to try some like setting to 3k 0 or 7 until you figured out whats the right one to neutral maybe that will do the trick i know is not a LAUNCH CONTROL but it helps a lot
    all the way from Tampico bay Mexico
    Tuner SuperG5's Avatar
    May 2021
    Mars
    50
    you can try negative timing in vacuum area of 4k.
    Quote Originally Posted by longlivelvmb View Post
    works for me . https://youtube.com/shorts/9t51-ibu020?feature=share
