Results 1 to 6 of 6
Thread: Gas 6r140 Transmission delayed shifts
    Sep 2020
    29
    Looking to see if i can get some suggestions on tuning changes i can make for the delayed shifts i get at WOT. The truck is a 2016 F250 6.2. i have made some changes suggested in other threads to improve torque converter lockup which helped. the issue seems to be if i floor the truck while cruising to pass it will downshift correctly but the next upshift hangs for a couple of seconds till i either lift briefly or it finally decides to shift.
    Jun 2018
    Albuquerque New Mexico
    467
    Quote Originally Posted by akley88 View Post
    Is this a new issue post making changes or was it happening with a stock tune? Post your tune file.
    Sep 2020
    29
    unfortunately i have always had the delayed shift issue at wot. maybe im just expecting to much out of a work truck.
    Jun 2018
    467
    This is missing tons of parameters, you don't even have any adaptive tables or shifting pressure tables. Contact support and ask to have them added, use the 17-19 F250-450 diesel file as reference for requested tables.
    Nov 2021
    If you are looking for Login Details, know about official employee login links & employee benefits, get all the access to your account easily.
    Apr 2024
    3
    Quote Originally Posted by JaegerWrenching View Post
    Do you tune or unlock these 6r140 transmissions?
