Results 1 to 10 of 10
Thread: cant read most tunes
    Jan 2021
    Miami
    351
    a lot of tunes i downloaded from repository cant read most of the tune, greyed out. NN is turned on, i tried to turn NN off and see if i could read but no change! any help on this? im trying to compare wot,pt and a few other tables but cant.
    By the prickle of my thumb something wicked this way comes!2008 Chrysler 300c! 2013 heads/220/230 comp cam/LTheaders/FTI 2600 stall converter.
    Mar 2018
    Illinois
    873
    When you compare tunes which version of editor are you using...latest beta or stable.
    Jan 2021
    Miami
    351
    4.10.5 ver. im trying to compare values for air flow and some spark tables but they are all greyed out.. NN is active so i turn it off in the caparing tune but still greyed out.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,265
    greyed out means one of the two files doesn't have those tables in it.
    Jan 2021
    Miami
    351
    tables are spark,airflow. shouldnt those tables be there?
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    Quote Originally Posted by Turbo2gnx View Post
    its probably there, but may be different size, loads, etc. so if its not an apples to apples comparison, it wont show in the compare view
    open the other file by itself, and youll see the differences
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Jan 2021
    Miami
    351
    when open without comparing it is the same.i noticed that its all the ones that have NN enabled. i disabled NN and still those tanles are greyed out. the body is 08 but the heads are from a 2013 5.7 with a 220/230 compcam and LT headers.
    Dec 2013
    Slidell, La.
    1,015
    Disabling nn does not change how the tables are defined
    your looking at two different operating systems, the greyed out tables are different between the two, therefore it is greyed out. Changing nn wont just magically make them the same.
    Michael Bray
    Slidell, Louisiana
    20yr Master Tech.
    Shop Owner
    Jan 2021
    Miami
    351
    wait, from the repository i download a 2006 hemi and the pt is greyed and all that are like this has NN enabled. ive compared many tables that were different in values but still comparable
    Dec 2013
    Slidell, La.
    1,015
    Its not the values, in the table, there are many things that determine this, like table size, x, and y axis using different functions, or different offsets. The only files that will be the same, are vehicles using identical operating systems. Different years will be different, even same year, with upgraded operating systems will show tables not the same. If its now "defined" the same, it will be greyed out.
    Michael Bray
    Slidell, Louisiana
    20yr Master Tech.
    Shop Owner
