I felt like the most compelling argument for using Excel was that you can organize the data as individual points in a scatter plot vs trying to average them. Averaging doesn't seem to absorb outlying values the same way a regression does. But murfie is the expert there. Being able to view the line is nice too, but I think the LINEST function can produce quadratic coefficients as well if you don't care for the visual. I do wish there was an easier way to contend with thousands of data points in a single log. My laptop hates this.
One thing I'm still trying to figure out is the blow through offset defined by point 208 in the patent. I'm fairly certain that this offset is different from the offset for the quadratic line, and I don't see a way of defining it in the tune or the calculator (although I think it is dependent on Exh. MAP). I assume that both Ford and the SD calculator find the intersect between the quadratic line and the max trapped air charge line, and somehow work back to a Y intercept from there.
It also looks like the quadratic line in the patent diverges from boosted MAP values, I wonder if I should not be including them in mine?
I can't find a way to tell Excel that a LINEST *needs* to go through a fixed non-zero point, and I'm not sure how to solve for a slope value and a missing point at the same time. What I've been doing is using the visual to help. Choose a good looking best fit point, generate a ballpark offset, and then move it up and down slightly until the line looks decent. I think there has to be a better way, but I also don't think my car is generating enough actual blow through to matter.
