DBW tuning or wiring issue?
I have an L86 swap and am trying to use a c6 corvette pedal. I originally wired it using this to the pins
https://cimg7.ibsrv.net/gimg/ls1tech...488e00057.jpeg
But after firing up the motor and getting no throttle output from the pedal and getting a bunch of codes, I realized that that the pins a/f don?t really mean anything unless you have the truck pedal.
So then I matched the wires to this c6 APP diagram.
https://cimg6.ibsrv.net/gimg/ls1tech...045f41116.jpeg
Still getting pedal codes
Figured it out. It was a misplaced wire. I pulled a wire the exact same color from the harness that was for oil pressure sensor ground. Hooked up the correct wire and all is good now.
