I have a 2K Sierra with a 5.3 with plenty of issues since I'm not certain of how to set this up. I'll preface this by saying I've been a mechanic and a hot rodder for 50+ years and am still old school. But, I can still learn. That being said, I picked this truck up from a guy who was pretty clueless, too, and he put a tune in it that allows it to run, but very poorly. Belwo are the engine specs:
Eaton 4:10 posi
built 4L60E transmission with 3k stall.
BTR stage3 cam with btr pushrods and jegs ls7 lifters,
long tube 1 7/8 headers with race pack mufflers and 3" true dual from headers back.
Now, I have a sneaking hunch that he tuned this with the EGR valve extremely loose and dangling. It's running pig fat and won't idle until it's warm. The shift points are way off, and the speedo works, but when coming to a stop, the truck stops and the speedo moves to zero very slowly which keeps the idle up and pulling against the brakes.
First question: The truck came with 4 02 sensors, he has two of them plugged in. There are no CATS so what should I do with, and how do I use the 02 sensors? I want to be sure the hardware is connected properly before I ask about the tuning he did. I did read the module and saved the tune. Can someone point me in the right direction of what to do with 02 sensors and the like?
TIA,
Greg
