reset long term fuel trims
specifically i'm working on a 18 tundra. i used the table to prevent it from going into closed loop, but i'm stuck with the 3 zones of long terms. is there a way to reset these? battery doesn't do it, total ecu unplug doesn't, flash doesn't. they see to be permanent memory. no special function in hpt either. help greatly appreciated.
have had the same issue with Supercharged with injector change, I just kept tuning, it takes time to re-learn but you can eventually get the LTFT trims back close to 0. I put in a support ticket to HP and they were not able to add a reset.
