Have a 17 l83 from a 2wd Silverado and 6l80e. My map sensor is on the intake. According to the vcm editor it was telling the pcm that the map was on the throttle body. Is that normal on the l83?s? For some reason I?ve never seen one like that before.
Car will start and idle, but not good throttle response. Not enough to try driving it. I can see why if it was thinking the map was in the wrong spot. Anything else I should look for when changing the parameters to the correct map sensor location? Any tips on tuning the off idle and mid throttle for a newbie?
