Originally Posted by
Chaseknight
Would you agree that this is a good way retune fuel trims
i had to set the maf fail frequency to 0 from 1 that you had because the dtc p0103 wasnt on but the p0102
was now that ive done the change from 1 to 0 it doesnt have p0102. is this a problem? was it a wrong move?
0 or 1 on the MAF fail freq won't matter. You were getting the P0102 because the MAF was disconnected. With either a 0 or a 1 in the fail freq, once you start the engine, it'll show a P0103 DTC
Quote : LTFT TUNING ?
A. In the VCM Editor>Edit>Engine Diagnostics>General>MAF Sensor Fail Frequency = 0. This will set a P0103 code and turn on the SES light. Ensure that the P0103 DTC is enabled and you are seeing P0103 in the DTC list. Don?t worry about the DTC at this time.
B. In the VCM Editor>Edit>Engine>Spark Advance>Main Spark vs. Airflow vs. RPM Open Throttle/Moving. Copy the High Octane table to the Low Octane table. The computer reverts to the low octane table when a MAF failure is indicated, this will assure optimal timing.*
C. Start the VCM scanner>Histogram display. File>Connect. Then Tools>VCM Controls>Fuel & Spark>Fuel Trim Learn>Reset Fuel Trims. *
D. Changes to the LTFT?s do not take effect immediately ? the PCM requires about 50 minutes or roughly 100 miles to allow for the PCM to relearn the fuel curve. Try not to enter PE mode while driving and logging for this procedure. Log about 30 minutes of driving at many different speeds and conditions. Try to hit as many cells in the histogram as possible. Stop logging and save the log. Do NOT turn off the engine until the log is saved or it will be lost. Go to VCM Scanner>Histogram display>LTFT's. Open the VCM Editor>Edit>Engine>Airflow>Main VE and select Primary VE vs. RPM vs. MAP. *
E. The goal is to get ALL LTFT?s between -5 and +5. Positive LTFT's indicate fuel is being added because of a lean condition. Richen this cell by increasing the VE table value by the amount of the LTFT value. The operation is opposite for negative LTFT's.*
If LTFT = (4), VE cell value is 67, result would be (67)+(4)=71 - increasing the VE, which is adding fuel. If the LTFT was (-4), the result would be (67)+(-4)=63, decreasing VE and thus reducing fuel. To decrease LTFT values, a smaller number or number closer to zero, ADD the difference between the positive LTFT value and zero to the corresponding cell in the VCM Editor>Edit>Engine>Airflow>Main VE>Primary VE vs. RPM vs. MAP table. To increase a LTFT value, a larger number or number farther away from zero, SUBTRACT the difference between the LTFT value and zero and SUBTRACT from the corresponding cell in the VCM Editor>Edit>Engine>Airflow>Main VE>Primary VE vs. RPM vs. MAP table. For example, In the VCM Scanner>Histogram display, the (.8, 40) cell, 800 RPM's and 40 kPa, is 4. To bring the VCM Scanner>Histogram display>LTFT cell (.8, 4.0) DOWN to 0 from 4 ADD 4 to the (.8, 4.0) cell in the VCM Editor>Edit>Engine>Airflow>Main VE>Primary VE vs. RPM vs. MAP table. If the VCM Scanner>Histogram display>LTFT cell (2.0, 30) is -10, SUBTRACT 10 from the (2000, 30) cell in the VCM Editor>Edit>Engine>Airflow>Main VE>Primary VE vs. RPM vs. MAP table to bring it UP to 0. This will not work out exactly but will be VERY CLOSE.
F. Repeat steps D-F until ALL values in the VCM Scanner>Histogram display>LTFT are between -5 and +5. *Try to complete this on the same day for best results as LTFT values can vary +-4% per day. *
G. Once all values are between -5 and +5, look at the VCM Editor>Edit>Engine>Airflow>Main VE>Primary VE vs. RPM vs. MAP>3D Surface graph. If the 3D Surface graph looks choppy, click on polynomial smoothing ONCE. This will smooth out the table values and provide a crisper throttle response. The table can also be hand smoothed using the 3D graph. Look for spikes in the table and increase/decrease the cells around the spike, creating a smooth table. Now rescan, and go back to step E. *
