I'm putting out 650lbs/ft of torque and trying to data log in 5th gear(A-8 transmission). I used to data log in 4th but with the Magnuson 2650 it breaks loose and spins at 60mph. So when I use 5th gear it gets to about 5000rpm and the Stibilitrac kicks in and puts me in limp mode. I have tried turning off TC by pushing the button twice, and tried holding it 13 seconds. It says off but still get the limp mode.
I did find a place in Torque Management under "Traction Control Method". It's set at like 485 but I'm putting out 650lbs/ft or torque. Is this where I raise the torque to keep the Stabilitrac from kicking in??
