Results 1 to 6 of 6
Thread: Can't change units on table - Bug?
    I was trying to modify the Pedal Percent Power Request Mode tables for a 2019 RAM. Clicking on the units to change from percent to other it disappeared and now I can't change it. Is there a way to reset all the units on tables?
    Tried with 4.11.628 Beta and 4.10.5 Stable.
    I managed to fix this.
    1. Close out of all VCM editors
    2. Open the VCM Editor.cfg file and remove the entry for your table under Parameters
    3. Save the file and re-open VCM editor.
    File location information:
    C:\Users\YOUR_USER_NAME_HERE\Documents\HP Tuners\Settings\VCM Editor.cfg
    https://www.hptuners.com/help/VCM-Sc...hitecture.html
    13,565
    I just right click the table and go down to units to change it back.
    I do that on the GM vehicles anyway.
    Thanks, can confirm this works also. Those tables have the number unit as an empty string which would explain the behavior. I've never had to report a bug before, is there an official way to report this so HP tuners sees it?
    7,627
    It's been like that since forever. Right-click menu to select the units is the fix.
    I must have gotten lucky over the last 5 years then. First time running into it.
