We have a 1947 chevy truck sitting on an 2006 envoy frame. Truck will crank fire and immediately die. the specs are as follows
5.7 LS! gen IV 58x wheel Texas speed 212/218 cam. The Harness is a painless ls2 harness designed for a 2006 and up truck 4l65e. The transmission is the stock 4l65e from the envoy. The tables look completely different from the stock 06 envoy tune to the tune that the trans has now. The vats are deleted. im seeing 158 mph from the vss, however inputs i believe should be different for this trans. the tcm is from a 2006-7 express van. attached are the data logs, and tune file. any help would be great.
bubbas 47 2.0.hpt
stocktune.hpl
