Hi,
I have a newer Windows 10 laptop and I can't install the MPVI1 drivers. I would upgrade to MPVI2 but I need to be able to datalog from a WB.
What should I do?
Hi,
What should I do?
MPVI1 and windows 10 are compatible
https://forum.hptuners.com/showthrea...r-installation
There must have been a recent update or something because these drivers are no longer compatible with windows 10.
Btw. I was able to install the latest chipset drivers but this was far from a user friendly install that anyone else can do.
After emailing HP Tuners tech support about this problem I too was having, They suggested the following which allowed me to access my MPVI1 Pro interface:
https://youtu.be/FBwGpeLgxbE
Basically, all you do is go to the search bar on your desktop, type in "Core Isolation" and turn off Memory Integrity. Restart pc, install drivers, connect to interface.
I had a code 39 under my device properties for the MPVI interface, and doing this fix allowed my drivers to install properly. Support said that they've used this fix before with people using Surface books and laptops with success.
Last edited by cabech984; 02-03-2022 at 06:56 AM. Reason: Edited for people in the future needing a code 39 fix
2006 Silverado RCSB, Cammed, D1X, 5.3L, TBSS Intake, FIC 1650cc Injectors, E85, 1 7/8" LT headers/4L80e swap/4.10 gears
