Working on a 1995 Chevrolet S10 with an LS3 swapped into it with what I believe is a GMPP E67 stand alone ecm. I'm experiencing issues connecting the scanner, it's been freezing / failing data log and then have to reconnect to the ecm and start to record again. You have to get the vehicle running and then press record of you don't get any datalog started and it's Also been closing the vcm scanner out of the blue. Vcm scanner work great on everything else ! Thoughts ?
