Was curious if this is a safe tune for the truck. 2015 3.5 ecoboost, pulling around 5,000 pounds for one pull. Other pull is a wide open throttle going down the road. Is 3 degrees of knock acceptable.
--thanks for all the help
I would remove 3 degrees. Your logs look like you got in the truck and floored it. How much KR are you seeing in the 2000-4000 rpm range? If it were me I would rather have less timing and let it add more if it needs it.
The only knock I've seen is above 5,000 rpm
I was suggesting removing timing only from the mapped ports where you have knock. In the quick log with the trailer you started off with 2.8 degrees of KR @3300. If it was me I would remove 2 degrees on mapped ports 6,7,8,9,10,11. Let the ECM add timing in if it wants it.
This was 88 octane. I put some lower grade fuel in to see if it would knock. I generally run 91
