Results 1 to 1 of 1
Thread: Weird scanner readings after windows 11 update
    Hello, could anyone give input on what was cause the WB and scanner not to match. This does not seem to be the usual scanner not matching situation. Deleted pid and re added and double check all the wires for something loose or exposed. battery voltage on car looks good. After update to windows 11 and doing a scan readings are all out of wack and i can tell by the wb reading. Whats weird though is that the scanner is showing the aem wb at 7.58 which is not what i commanded and the scanner itself is showing 48 in every field on the error correct table now. I have tried repoll, resync, ect but still showing the same number in every table. Any input would be appreciated. I have the car in OL and everything on the fuel side looks correct as well.
    Thank you for you time.
