Thread: Idles fine but bog under acceleration and dies
    Oct 2016
    5
    Getting my ls swap finished up but having some issues
    idles and turns on fine but bogs bad under acceleration and if i hold gas peddle down long enough it dies.
    6.0 holley high ram full bolt on 42lb injectors with th400 trans
    i have changed the injector flow rate
    foxbody ls swap 1.hpl
    13,565
    Did you change all the other injector data?
    Did you fail the MAF sensor in that tune file?
    Oct 2016
    5
    I have not
    Nov 2021
    Colorado
    53
    Did you check for vac leaks? Simple stuff can sometimes be the cause of huge headaches
