Need help with injector EOIT/ boundary when using ethanol blend and bigger cam
Thanks in advance for any help.
Gen3 PCM but with 416 cubic inch LS3 stroker swap, I have issues with idling, bad fuel smell, and more importantly bad cam surge under 2000 RPM.
Motor is 12.8 compression, running E45 ethanol blend. Cam is 235/242 (@.050) 111 LSA +2, which I believe is 288/295 at .06
Can someone help me calculate what Boundary and EOIT normal table values I should use? Current boundary is set to stock 6.5, with 5.55 set in most of the EOIT table see below.
Because I am running E45, I know ethanonol has a different evaporation rate than gas.....
I tried going through the various spreadsheets listed by doing a search, but I am very confused as to what I need to do, and no one seems to address the ethanol blend part of it.
