Results 1 to 2 of 2
Thread: Lean Angle gauge
    Nov 2021
    2
    Question Lean Angle gauge
    First off, Hello everyone.
    I've used google and tried my search else where, so figured now I should ask the forums. H
    ow do I get the overlay for the lean angle in regards to motorcycles.
    Apr 2018
    296
    If you have a column or field for Lean Angle in your data file, then it's usually pretty simple.
    I'd recommend checking out these posts:
    https://forum.hptuners.com/showthrea...ght=lean+angle
    The first thread has a sample Lean Angle gauge. Depending on the data that you have, you may need to adjust the Range (currently in radians of -1.57 to 1.57, but degrees would be more like -90 to 90 or 0 to 180).
    If you don't have a field for Lean Angle, then it's a bit more difficult to first calculate and then use a Gauge to display it.
    RaceRender is particularly good at displaying the data that you already have and gives you a lot of freedom to make it look exactly how you want with the Enhanced Script Editor, but if you don't have the data, then RaceRender likely can't help. It can do some calculations based on GPS coordinates, but Lean Angle wouldn't be one of them.
