Need advice.
Have stock bottom LS3, mods in sig. Whipple is at about 10psi of boost. Car runs great. Its flex fuel sensor equipped and tuned. When I am able to get good e85 (Sunoco) and get E concentrations in the tank up >=70% it doesnt like to start on the first button push with the engine cold. Always fires off the second, and starts first try when engine is warm.
I tried adding 2deg of timing for rows at and below 68F in "Cranking Spark", logged and i see its at 13deg cranking instead of 11deg for the start.
Added 20% fuel in rows at/below 68F in "Cranking FA Mult Stage 1 vs Cranking Time".
Note its about 66degF outside based on IAT reading at cold crank.
Running NGK Iridium ID TR7IX plugs. LSA/LS7 valve covers w/stock GM LS7 coils. Whipple kit had recommended gap of 0.035, they are set currently at about 0.032.
Any advice where to go to improve cold start behavior would be appreciated!
Pulled plugs just to have a look, have about 10k miles on them. I'm a total novice at plugs, at my skill level i don't see any issues visually.
Thanks!
base tune that fails to start on first attempt
2016 chevy ss m6_6.2l_whipple 2.9l id1050x FF v1.hpt
revised tune containing added fuel and spark
2016 chevy ss m6_6.2l_whipple 2.9l id1050x with added cranking fuel and spark for e85 attempt at.hpt
log file of start attempt with added fuel+spark
added cold crank fuel and spark for E85- did NOT help 12.4.21.hpl
Many thanks in advance for input.
