Results 1 to 10 of 10
Thread: 2007 Golf GTI Tune Assistance
    Jan 2019
    Australia
    85
    Hi,
    Firstly I would like to thank the people in here for sharing their knowledge on the VW/Audit platform. It has been especially helpful for someone like myself who is more comfortable with the Holden/GM & Fords.
    I am attempting to tune a 2007 Golf GTI MED9.1 and seem to have hit some sort of torque limit which is preventing me from reaching my desired boost but I can't for the life of me figure out the issue.
    I have attached my recent tune and log file and would greatly appreciate any suggestions that you could provide.
    Cheers,
    JasonDaves 2006 GTI Mod 3.hptMod 3.hpl
    Sep 2014
    17
    i believe the oil temp limiter is what you missed - in bosch its LDPBN
    Jan 2019
    Australia
    85
    Thank you very much for taking the time to look over my tune. I completely overlooked that one!
    I will let you know the outcome.
    Cheers.
    Sep 2019
    ON, Canada
    361
    Are you running some kind of aftermarket boost controller? I see very high duty and throttle but no more than16psi
    Jan 2019
    Australia
    85
    Hi Tyler, I believe its the factory boost controller. Being my first time playing with a torque based ecu, I wasn't sure if it was a limiter preventing my delivered engine load from matching my desired engine load, causing my actual boost to fall way short of my boost target, or if perhaps there is a boost leak somewhere.
    I don't have the car at the moment. Told my mate to go over it and check for boost leaks, but hope to have another crack at it this afternoon.
    Thanks for chiming in too. I have found your posts to be most helpful.
    Cheers.
    Sep 2019
    ON, Canada
    361
    Quote Originally Posted by JasonHSV View Post
    Cheers.
    really looks to me like a failing wastegate or DV, have a look and see if you can find anything then report back
    Jan 2019
    Australia
    85
    Yes we were thinking a faulty DV as well, especially considering how sharply the boost drops off. He is going to take it out today and inspect it.
    Thanks again.
    Jan 2019
    Australia
    85
    Just an update, the DV was split so he has ordered a new one. Will see how it goes when it arrives.
    Jan 2025
    6
    I am new here i have gti 2007 med9.1 change forged piston 9.1 1 compresion k04 turbo 62.6mm aluminum intake manifold oil catchcan the car is misfiring i try to tune my ecu but like i say i am new on this of tuning i am really interesting on learning. Thank you
    Jan 2025
    6
    issue with idle
    11.hpl11.hpl
    i have issue with idle is like misfire no all the time is just for few sec.
    i am runing 93 fuel what i am missing
    and thank you.
    have Forged H-Beam connecting rods
    144x20mm forged H-beam ,
    JE Forged Piston Set
    82.5mm bore (standard), 9.1:1 compression ratio, 92.8mm stroke
    Calico Coated ACL Race Main Bearing Set - Standard Clearance
    Calico Coated ACL Race Rod Bearing Set - Standard Clearance
    Lightweight Underdrive Crank Pulley Kit
    2.0T FSI / 2.0 TSI Aluminum Intake Manifold
    K04 F23T Turbocharger Manifold (Billet Compressor Wheel 62mm)
    STAGE 3R CLUTCH KIT+PROLITE FLYWHEEL
    intake air filter K/N
