Results 1 to 4 of 4
Thread: help with transform function for 30-4406
    Apr 2020
    11
    so i wired up my prolink today and added 2 channels to my vcm scanner. my wideband and boost gauge. the issue is im not seeing the correct values with the boost gauge. i found a transform code for the wideband and its now looking very accurate to what the gauge is showing. but this boost gauge is fighting me and i cant seem to find any support. the vcm values dont seem to translate correctly. at idle the car is pulling 22in of vacuum and the vcm will show 4-5lbs of pressure. i messed around a bit and when using input .08 output -32.25 values i can get it read the idle vacuum, but it doesnt cooperate when tapping the throttle. has anyone had this issue or can anyone offer some advice?? thanks..
    Jan 2014
    Australia
    1,982
    what linear and offset values were supplied with the boost sensor ?
    Apr 2020
    11
    it was in the car when i bought it so i dont know
    Jan 2014
    Australia
    1,982
    did u use the preset boost values for it in the transform section ? (input / 0.8) + -6.25
