Originally Posted by
murfie
It's idling lean. The command is very rich to make up for it and get the sensors to read lambda 1.
9.5 or so MAP, shows you have good vacuum and very likely no leaks.
You have fixed your fuel pump so I assume you rail pressure is at 58psi.
You could also have an exhaust leak.
Assuming everything mechanical is working. you can use the HPT SD calculator and add 15% to MP 0 rpm columns encompassing 500-1000. Have it recalculate the coefficients. Relog and see where your air load and fuel command/ trims at idle falls then.
