Results 1 to 20 of 24
Thread: Intake Manifold Absolute Pressure (SAE) reading is way way off
    Tuner Turbo6TA's Avatar
    Nov 2021
    SW Florida
    92
    2011 Corvette LS3 (Gen 4) with Magnuson 'Heartbeat' supercharger
    mpvi2
    ____________________
    I just started using the HP Tuners and did a log file with the VMC Scanner today.
    I know that my max boost from this supercharger is about 7 PSI, but today, when logging "Intake Manifold Absolute Pressure (SAE)" it showed 22 PSI of manifold pressure when at WOT @ 6,200 RPM.
    Now, I know for a fact that this supercharger don't make anywhere near 22 PSI of boost.
    Any idea as to what is going on here ?
    Thanks,
    Ron
    Mar 2021
    Colorado Springs, CO
    36
    I would look at your MAP scaling.
    Nov 2021
    SW Florida
    92
    Unfortunately, I don't have a clue as how to re-scale the MAP. The car was professionally dyno tuned after the supercharger was installed.
    The MAP sensor is the standard LS9 sensor that is supplied with the Magnuson supercharger kit.
    The car runs great, but why it don't show the correct boost pressure using HP Tuners had me confused.
    Looking at the file, I see that the Intake Manifold Absolute Pressure (SAE) shows 8.3 PSI during idle ... just ain't right !
    Jul 2020
    VIC Australia
    1,165
    Absolute pressure means in a perfect vacuum it'll read 0psi. At atmospheric pressure it'll read around 14.7psi +/- a bit depending on weather and altitude.
    You need to create a custom math parameter.
    MAP abs - Baro = Boost
    Nov 2021
    SW Florida
    92
    I guess I need to figure out how to create a custom math parameter.
    Here is a photo of the log file showing the 22 PSI boost at the top of a WOT acceleration in 3rd gear (A6 trans):
    _______________________________
    Mar 2021
    36
    Take the Part number off your map sensor. Search for the data and offset. On your engine> Airflow tab you will have the spots to put that info.
    Nov 2021
    SW Florida
    92
    Well, I found it for the LS9 . 3-BAR sensor . . P/N: 12592525
    Linear (312.50 kPa)
    Offset (-11.25 kPa)
    ___________________________________
    I am thinking that the "Linear" would go where it says "Slope" in the photo above, and "Offset" would obviously go in the "Offset" photo above ? ?
    Oh Wait ... I see those 312.50 and -11.25 numbers are already included in the "Characteristics MAP Sensor Linear and Offset" sections of the photo I posted above.
    Mar 2021
    36
    yes if thats the sensor you have
    13,571
    No, the linear and offset setting are already in there for the MAP sensor. You don't touch the BARO settings.
    Nov 2021
    SW Florida
    92
    So, how would I get the it to read my correct 7 PSI (give or take) boost at WOT ?
    13,571
    Post #4 told you what you gotta do. Make a custom math channel for boost and then that channel will read what you want.
    Or just learn to read MAP kpa in the logs to determine boost. That's what I do anyway for most things.
    Nov 2021
    SW Florida
    92
    Well, that's what I need to do ... Unfortunately I don't have a clue how to even start making a 'custom math channel' (sounds like Rocket Science to me)
    Please excuse my ignorance
    Nov 2021
    SW Florida
    92
    I tried to post a copy of my tune here ... I right clicked the tune and then copied it ... then tried posting it here, but it never showed up in my post to you.
    Jul 2020
    VIC Australia
    1,165
    ___
    Nov 2021
    SW Florida
    92
    Thanks hjtrbo ...
    It now shows up in the Math Parameters Manager .. under 'Maths-User' .. with the name 'Boost'
    So, the next time I log a run, I will get the correct boost pressure value next to Intake Manifold Absolute Pressure (SAE) ???
    Australia
    1,986
    just add it to your chart v time with min/max values and it should work fine, just make sure in the maths when selected that the pids are not red where hjturbo showed ID box
    Nov 2021
    SW Florida
    92
    In my Math Parameters Manager . . ID 6100 . . Name: Boost
    The ID 50030 > Manifold Absolute Pressure [Sensor] is not red
    The ID 50032 > Barometric Pressure [Sensor] is red
    Australia
    1,986
    u need to add that baro to the channels list, press the gear with the green + on it and u get the list of pids then u can type in the 50032 to find the baro then add it in the list and it should remove the red next time u connect the vehicle and log, then that boost pid will work
    Nov 2021
    SW Florida
    92
    You guys 'down under' have been a great help !
    Ok, the red color disappeared ... It's nighttime here right now. I will do a log in the morning and see if this works.
    Thanks a bunch for you and everyone else that has helped me through all this.
    I just got this HP Tuners about a week ago, and I feel like a real idiot trying to explain all this to you folks that obviously know a hell of a lot more about HP Tuners than I will probably ever know.
    Again, thanks ...
    This will more than likely not be the last time you hear from me and my silly questions.
    Ron,
    Nov 2021
    SW Florida
    92
    BTW ... Here is the Corvette ...
