Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: Intake Manifold Absolute Pressure (SAE) reading is way way off
  1. #21
    Tuner Turbo6TA's Avatar
    Nov 2021
    SW Florida
    92
    Well ... I must of done something wrong, because it still don't show actually intake manifold boost (above atmospheric pressure).
    All I want is to see something like 7 or 8 PSI boost while at WOT in the top of the gear.
  2. #22
    Jan 2014
    Australia
    1,983
    may be because if u made one u now have two, delete yours and use the factory one under the airflow extension in the maths, its the same expression but having two of things can sometimes cause issues, also if still dosnt work post up a log so we can see whats going on
  3. #23
    7,646
    Learn to use the KPA that the MAP sensor displays. It makes more sense anyway, requires no math, and everything in the tune file is using the absolute pressure and not the Ye Olde Timey gauge pressure you are wanting to see. If you can get to intuitively know what the KPA absolute means your life will be a lot easier.
    But, continue if you like. Bonus points if you can get the custom math to convert less-than-baro readings (vacuum) into inches of mercury and higher-than-baro (boost) into PSI.
  4. #24
    Jan 2021
    5
    Thanks for posting how to add a boost gauge to the scanner. I have a SC 3800
