Page 3 of 3 FirstFirst 123
Results 41 to 47 of 47
Thread: help with eoit tuning
  1. #41
    Dec 2013
    48
    oh yeah i needed to do the difference that makes sense.
    so i guess this is what i should start with.
    did you leave all the normal ect and rpm alone?
  2. #42
    Jun 2014
    Boulder, CO
    202
    Those numbers for higher RPM look small to me but I'm not sure how you arrived at them or what your engine is. My ECU is an E67, maybe yours is different. My "Makeup ECT" table is all 30 and my "Normal RPM" table is all zero. My "Normal ECT" table is below. I played with several versions in the Excel spreadsheet and tried about 8 or 9 version on my engine before settling on the table I posted.
  3. #43
    Australia
    1,981
    best to leave the makeup ect as 30 or 20 but going too low can cause issues, seems like that is a reserve amount, just adjust the normal ect, normal rpm to zero, use boundary for rpm
  4. #44
    Dec 2013
    48
    thats just 17 added to the factory table. this is a e38 2008 g8
  5. #45
    Australia
    1,981
    e38 and e67 share same eoit tables, the gen5 is where it uses airmass as well
  6. #46
    Arizona
    439
    is this / does this work the same for GEN3/4 engines/ECUs?
  7. #47
    Australia
    1,981
    they have similar outcomes but gen4 is more adjustable settings wise, also the way they are adjusted is totally different
